Lyssna på band - Datormagasin Nr. 6, 1987:
Commodorianen skrev:Det programmet knappade jag in när det numret av Datormagazin kom 1987. Ljudkvaliteten var förskräcklig men jag var fascinerad över att det överhuvudtaget gick att lyssna på band på det sättet.
100 fora=0to93:readb:c=c+b:poke50000+a,b:nexta
110 ifc<>9978thenprint"data error ";c:list
120 sys50000:print"installera med sys50000"
130 print"_h lyssna, space avslutar"
140 data 169,91,141,8,3,169,195
150 data 141,9,3,96,32,115,0,240
160 data 4,201,95,240,3,76,231
170 data 167,32,115,0,201,72,240,3
180 data 76,8,175,120,169,87,133
190 data 1,169,0,141,17,208,173,1
200 data 220,41,16,240,32,173,13
210 data 220,41,16,74,208,11,169
220 data 0,141,32,208,141,24,212
230 data 76,123,195,169,1,141,32
240 data 208,169,15,141,24,212,76
250 data 123,195,169,55,133,1,169
260 data 27,141,17,208,76,116,164
.C:c350 A9 5B LDA #$5B
.C:c352 8D 08 03 STA $0308
.C:c355 A9 C3 LDA #$C3
.C:c357 8D 09 03 STA $0309 ; set address of BASIC instruction execution
.C:c35a 60 RTS
.C:c35b 20 73 00 JSR $0073 ; this is the new BASIC inst. exec. address, increment and scan memory
.C:c35e F0 04 BEQ $C364
.C:c360 C9 5F CMP #$5F ; compare to left arrow
.C:c362 F0 03 BEQ $C367
.C:c364 4C E7 A7 JMP $A7E7 ; no arrow, interpret BASIC code as usual
.C:c367 20 73 00 JSR $0073 ; increment and scan memory
.C:c36a C9 48 CMP #$48 ; compare to H
.C:c36c F0 03 BEQ $C371
.C:c36e 4C 08 AF JMP $AF08 ; not H after arrow, show syntax error message
.C:c371 78 SEI
.C:c372 A9 57 LDA #$57
.C:c374 85 01 STA $01 ; datassette motor on
.C:c376 A9 00 LDA #$00
.C:c378 8D 11 D0 STA $D011 ; screen off
.C:c37b AD 01 DC LDA $DC01 ; fetch data from port B
.C:c37e 29 10 AND #$10 ; only keep bit 4
.C:c380 F0 20 BEQ $C3A2
.C:c382 AD 0D DC LDA $DC0D
.C:c385 29 10 AND #$10 ; keep datassette input
.C:c387 4A LSR A
.C:c388 D0 0B BNE $C395
.C:c38a A9 00 LDA #$00
.C:c38c 8D 20 D0 STA $D020 ; black screen
.C:c38f 8D 18 D4 STA $D418 ; no volume
.C:c392 4C 7B C3 JMP $C37B
.C:c395 A9 01 LDA #$01
.C:c397 8D 20 D0 STA $D020 ; white screen
.C:c39a A9 0F LDA #$0F
.C:c39c 8D 18 D4 STA $D418 ; MAX volume
.C:c39f 4C 7B C3 JMP $C37B
.C:c3a2 A9 37 LDA #$37
.C:c3a4 85 01 STA $01 ; default setting, datassette motor off
.C:c3a6 A9 1B LDA #$1B
.C:c3a8 8D 11 D0 STA $D011 ; screen on/normal
.C:c3ab 4C 74 A4 JMP $A474 ; do warm start
e5frog skrev:Denna funkar, du behöver inte skriva SYS5000, det görs redan i programmet, använd piltecknet uppe till vänster på tangentbordet, inte någon kombination av < och -:
- Kod: Markera allt
carlsson skrev:Listningen i Oberoende COMputer försökte jag också att mata in. Jag fick inga felmeddelanden, men inte tusan hördes några vettiga ljud, vare sig jag spelade upp databand eller musikband. Jag knappade nog in den från Datormagazin också, minns inte om den fungerade bättre för mig.
Blacker skrev:I DMZ's listning avslutas rad 110 med ":end" och den versionen funkade inte för mig, däremot e5frogs version som istället har ";c:list".
