Triton Quick Disk for C64
Inläggav d0c » 9 april 2007, 14:08
her er en raritet av et disk drev for c64, skannet inn fra commodore user 1985..
hvis du har problemer med og lese. kan du laste ned bildene i 100% kvalitet her..
http://www.sendspace.com/file/lwinzk
HARDWARE:
Large cream coloured disk drive unit with integrated power supply and mains lead to black coloured interface box which connects to the Commodore 64 system edge connector.
SYSTEM DESCRIPTION:
Although the TRITON QUICK DISK uses hardjacketed floppy disk media, it falls under the category of the stringy floppy systems, as the access is not random but sequential. Unlike the standard disk drives where individual tracks may be accessed by positioning the read/write head with the step motor, the TRITON QD combines the floppy disk rotation with a continuous linear tracking of the head and thus creates a single spiral track along the disk similar to a record groove. The spiral is completes within eight seconds whereupon the linear motion disengages and returns to the start position. This means that consecutive access time is restricted to eight seconds. In general, this works out faster than the Microdrive and similar to the Wafadrive. Formatting requires only one go and this means an extremely fast formatting time. The interface caters only for one drive and should a second drive be required, a second interface will have to be installed.
MEDIA:
2.8inch jacketed floppy disks with write protect tab.
TECHNICAL SPECIFICATIONS:
Max number of drives per system: 2
Storage capacity (formatted): 100k (2 sides)
Number of sectors: 20 per side
Sector size: 2.5Kbytes.
Data transfer rate: 101.6 Kbits per sec.
Recording density: 4410 BPI
TIMING:
Formatting: 8 sec.
Cataloguing: 2.5 - 8 sec.
Loading screen: 2.5 - 8 sec.
Inläggav Commodorianen » 9 april 2007, 14:15
Lagring på 2,8"-disketter :o . Det har jag nog aldrig sett tidigare.
Inläggav d0c » 9 april 2007, 14:24
her er litt info om 2,8 inch floppyen....
A Smith Corona DataDisk 2.8-inch actually measures about 3 1/32-inch square. This disk is one of the few different Mitsumi Quick Disk packages, which vary in storage capacity and casing size. The Quick Disk uses a 2.8-inch magnetic media, break-off write-protection tabs (one for each side), and contains a see-through hole near center spindle (used to ensure spindle clamping). Note the label "A" to indicate disk side. The backside has a "B" label.
The Quick Disk was also used in several MIDI keyboards and MIDI samplers of the mid 1980s. A non-inclusive list includes: the Roland S-10[15] and MKS100 samplers, the Korg sqd1, the Korg SQD8[16] MIDI sequencer, Akai's 1985 model MD280 drive for the S-612 MIDI Sampler,[17][18][19] Akai's X7000 / S700 (rack version) [20] and X3700,[21] the Roland S-220,[22][23] and the Yamaha MDF1[24] MIDI disk drive (intended for their DX7/21/100/TX7 synthesizers, RX11/21/21L drum machines, and QX1, QX21 and QX5 MIDI sequencers).
kilde:
http://en.wikipedia.org/wiki/Floppy_disk
Inläggav Commodorianen » 9 april 2007, 14:30
Disketten kallas Quick Disk ser jag. Det finns en C64-lagringsenhet som kallas Quick drive (eller något liknande) har jag sett i annonser. Jag undrar om det är relaterat till Quick disk. Jag har dock fått uppfattningen att Quick drive är en stängd enhet som man inte kan byta lagringsmedium i (ungefär som en hårddisk) och inte en enhet som man kan sätta i disketter i. Det kan dock vara fel.
Inläggav Commodorianen » 9 april 2007, 14:38
Nej, Quickdrive använde tydligen lagring på band.
Inläggav d0c » 9 april 2007, 15:03
Commodorianen skrev:Nej, Quickdrive använde tydligen lagring på band.
en quick drive kan du se her ;)
http://8bit.dk/pictures/?f=Commodore_Qu ... _Brand_New
Användare som besöker denna kategori: Google [Bot] och 6 gäster
