New C64 motherboard - C64 Reloaded
Inläggav d0c » 7 maj 2014, 12:53
The Commodore 64 will celebrate it's 32nd birthday this year, and that's a significant birthday for a Computer: If written in hexadecimal notation, 32 becomes $20. After such a long time, more and more C64 boards are failing and can't be repaired any more: Even after exchanging all chips, a board may still not work. A possible cause for this is a defect of the circuit board, which is extremely tedious and expensive to find and fix.
We will therefore produce new C64 mainboards shortly. We have kept close to the schematics of Commodore Assy number 250466, because this version is accepted to be the best compromise between cost savings and compatibility. We have only changed the circuit in very few places, so production is still possible with parts that are available today.
C64 Reloaded will fit in all original C64 cases: The classic "breadbox" cases and the flat versions of the case that were used in later production years. We've had a positive surprise when measuring the power consumtion, because our new mainboard uses modern DC-DC converter technology: We use an EuP-compliant 12V DC wall power supply that will use less than 0.3W(*) in standby. The original C64 requires 3.9W(*) in standby, and when powered on, power consumption rises to 21.6W(*). Our C64 Reloaded only takes about 5,7 Watt(*) - roughly a quarter of what the original computer required, despite the fact that we're using the original Commodore chips. This economical approach doesn't mean "weak" in any way: The DC-DC converters have lots of power reserve to supply even very power-hungry expansions like the "Super CPU" or the Commodore memory expansions 1750 or 1764.
The C64 Reloaded does not come with a TV-Modulator. There's an S-Video output in it's place, and audio is passed to the outside world through a 3.5mm stereo plug, which lets you use standard audio equipment. The known connectors for joysticks, cartridges, monitor, floppy drives, data cassette and userport are of course available on C64 Reloaded.
C64 Reloaded will be shipped partly assembled: The processor (CPU) and the sound chip (SID) are not included and need to be put into ZIF-sockets by the customer. The PLA and video chips are also in zero-insertion-force sockets, so they can be exchanged easily. As opposed to the original computer, our board can be jumpered between PAL and NTSC without the need to solder anything. By customer request, the board can be equipped with two Kernal ROMs and two character ROMs, which can be chosen by pressing and holding the Restore key. This way, you can use popular speeders and localizations such as German and Swedish Umlauts.
links:
http://icomp.de/news/news147_e.htm
http://wiki.icomp.de/wiki/C64_reloaded
Re: New C64 motherboard - C64 Reloaded
Inläggav joshuadenmark » 16 september 2014, 21:15
Nogen som ved mere om dette? Evt. om det var en joke?
De bedste hilsner
Peter Jensen - Denmark
_________________________________
Vic20 - Commodore C-16 - Commodore 64 - Commodore Plus 4 - Commodore 128 - Amiga 500 - CDTV - Easy Flash - Final Expansion 3 - SD2IEC
joshuadenmark
Gesäll
Gesäll
Inläggav carlsson » 17 september 2014, 09:44
Enligt inlägg på CSDb den 23 juli hade återförsäljaren Vesalia fått följande svar från Individual Computers:
The second prototype is still pending verification, and this will most likely remain that way while the USB module is on top priority. We'll do our best to show the second prototype of the C64 Reloaded at the Gamescom in August (http://www.gamescom-cologne.com/en/game ... /index.php), but there's currently no release date for production units.
Jag försökte att söka bland utställarna på Gamescom 2014 (335000 besökare!) men hittade inte Individual Computers där, så det kanske inte blev något av det.
När nyheten publicerades var Jens tydlig om att det inte skulle vara ett aprilskämt, och just därför gick de ut med nyheten 1 april. Från början skulle man kunna förbeställa från juli, men ovanstående i kombination med att de gjort om hemsidan och webbshoppen som kanske tagit mer tid än planerat kanske gör att den fördröjs. Tiden får utvisa om den blir tillräckligt lönsam att producera.
Inläggav d0c » 3 oktober 2014, 18:24
håper på det best og at det blir noe av dette prosjektet. vi trenger nye c64 maskiner, siden de gammle c64 maskinene nå nårmer seg 33år...
Inläggav Nazca » 3 november 2014, 17:54
d0c skrev:håper på det best og at det blir noe av dette prosjektet. vi trenger nye c64 maskiner, siden de gammle c64 maskinene nå nårmer seg 33år...
Ja, det vore trevligt, jag hade köpt en eller två direkt.. nu har jag 3 C64:or i garderoben men 2 av dom används som "donatorer" när nåt chip eller nåt annat går sönder på min primära burk. Hade känts skönt med ett helt nytt kretskort och med snålare/stabilare strömförsörjning och S-Video som videoutgång därtill.
Nazca
Inläggav hedning » 5 november 2014, 10:16
Jag såg och tafsade på två prototyper på X2014 i Holland.
...::] Genesis Project - Accept No Limits [::...
SX-64, C64GS, silver badge c64, Brödbox, C64C, C64G, Drean C64C, VIC20, Plus/4, C16, C116, C128, C128D, Atari 520 STfm, Atari 1040 ST, Atari Falcon 030, Amiga 500, Amiga 600, Amiga 1200, CDTV.
hedning
Inläggav Nazca » 5 november 2014, 17:27
hedning skrev:Jag såg och tafsade på två prototyper på X2014 i Holland.
Trevligt att höra att de finns på riktigt i alla fall 8)
Nazca
Inläggav bjonte » 5 november 2014, 21:32
Ja, det skulle kännas tryggt med något sådant när datorerna klappar ihop. Det kommer inte att bli roligt annars.
Inläggav corpsicle » 17 april 2015, 06:16
Jaha nu är dom alltså ute på auktion.
Någon som är sugen på en för 200+ eur?
corpsicle
Inläggav e5frog » 17 april 2015, 19:55
Det är en mindre omgång fullt utrustade kort som auktioneras ut, vi fattiga får sedan handla de överblivna resterna - om man känner att behöver någon alls. Det är väl dessutom auktion via e-mail.
Inläggav sledge » 27 september 2015, 16:34
Hur härligt som helst. Jag har fått en avi om att jag har ett C64 reloaded som väntar på posten. Så i morgon så blir det till att datamysa hela kvällen!
Jag har ju ett gäng 6582A, SuperPLA och keramik VIC-II som ska få populera moderkortet :)
Inläggav bjonte » 27 september 2015, 16:45
Vad avis jag blir. Ha det så roligt! Vad blir första testet?
Inläggav sledge » 3 oktober 2015, 17:23
bjonte skrev:Vad avis jag blir. Ha det så roligt! Vad blir första testet?
Det har jag faktiskt inte kommit fram till ännu. Kortet saknar 6510, PLA och SID. Övriga kretsar fanns redan monterade. Planen är att jag ska rota fram dessa från mina flyttkartonger (som inte blivit uppackade ännu sedan flytten till Värmland). När väl det är på plats, och kortet är monterat i ett skal, så ska jag ta mig en funderare på vad som ska få bli primärloadningen på den :)
Inläggav herdware » 3 oktober 2015, 19:29
Håll oss uppdaterade!
