Replika på 1581
Replika på 1581
Inläggav herdware » 24 maj 2020, 18:55
Någon/några har alltså plitat ihop en replika på 1581 moderkort. Skillnaden mot en riktig 1581 är bl.a. att det går att använda en 65c02 istf 6502 och modern SRAM.
Med en adapter ska det även gå att använda en vanlig PC-floppy istf en Amiga-dito.
Min tyska är är rätt skral så om någon är duktigare får de gärna fylla i med info.
https://www.forum64.de/index.php?thread/102472-1581replica-gotek1581-1581-pc-drive-adapter/
Blir förstås inte samma sak utan skalet men ändock ett kul projekt.
Undrar hur man kontaktar upphovsmannen utan att bli medlem på ännu ett forum...
Kom osökt att tänka på 1582/1590/1591. https://www.floodgap.com/retrobits/ckb/secret/periph.html
The 1591 aka 1590 is apparently an HD 1581. ROMs for the 1591 are known to exist, but it is uncertain if the drive itself ever even entered prototype status. A replica 1591 has been constructed from the 1591 ROMs and the A4000 drive mechanism by Steve Croucher, although Steve no longer possesses it.
The 1591, were it produced, would have been very unique for the way it dealt with the issues of high-density storage, according to Nicolas Welte. Amiga FD controllers can only cope with data at a fixed rate. For the lucky Amiga drives that can use HD media, and presumably for the 1591, Commodore slowed the disk spin to 150rpm instead of the normal 300rpm to read in the extra data at the same rate.
James Crook reports a 1582 based on correspondence with one confirmed owner. This appears to be a unknown HD 3.5" mechanism in a A1010 case and upgraded 1581 firmware on a slightly modified 1581 mainboard, and like the 1590/1, can apparently use 3.5" HD media. The owner states that it only reached prototype status, his unit being #2 of six, but no additional information was ever provided. It is also not known whether there is any relationship between the 1582 and the 1590/1.
Hade varit kul att se moderkortet på 1582. Synd att ROM:arna inte finns arkiverade från några av dessa... Antagligen behöver även den en Amiga HD-floppy som läser HD-disketter i 150rpm istället för 300rpm.
Annars hade det varit roligare att bygga sig en 1582. :commodore:
