herdware skrev:Gillar inte riktigt att de tog bort platserna för riktiga SID...
storhemulen skrev:??? Det sänker nästan projektet för min del också.
The Trapdoor gives you easy access to the PMODs and the MEGA65 internals. So YES, real SIDs, VGA, Blutooth, GPS.
You can connect to it, what you want, as long as you implement it in the VHDL code. Datasette port maybe ?!
Real SIDs will go on an expansion board and work flawlessly. Would have added crazy cost to make space on 6-layer PCB for them.
The exact function of the board will be determined when it is created. But we are planning on the R3 PCB to have a header that allows the 3.5mm jack to be routed via the SID board. There is nothing stopping the board supporting 6581s in principle. We have 12V DC available on the PCB, so that isn't a problem.
384KB of primary RAM, then soon an 8MB expansion RAM will be activated. Primary RAM is at full 40MHz clock speed, expansion RAM will be "slow" at only 8MHz or so.
herdware skrev:Mega65 har inte varit kickstarter (än). Du måste tänka på något annat.
