Världens mest ombyggda Commodore 128D?
Inläggav carlsson » 3 februari 2011, 19:28
Jag hittade detta inlägg på ett annat forum:
Bungo Pony @ Vintage Computer Forum skrev:This has got to be one of the coolest things I've ever found. It's a Commodore 128D which someone has transported into a new case and has built a bunch of cool accessories into it! Whoever built this thing put a LOT of work into making it the ultimate Commodore computer. I haven't powered it up yet to see if it works, as it's been sitting out in -25 degrees Celcius. I probably won't get to play with it until the weekend.
Anyway, what good would this post be without pictures of the outside and the inside of this thing. They mounted the motherboard right at the bottom of the case and stacked the floppy drive boards on top of each other. The power supply thankfully has a cooling fan which is probably necessary with all the heat this thing would generate.
On the front panel, there is a little door on the left side that you pull open, exposing a bunch of switches and knobs so you can set your Commodore to the exact settings you want.
I'm blown away by how many features are packed into this thing. The LEDs on the front panel are even wired up!
Anyway, I'll shut up and let you look at the pictures. Really amazing!
http://www.files.classicalgasemissions. ... 128-01.jpg
http://www.files.classicalgasemissions. ... 128-02.jpg
http://www.files.classicalgasemissions. ... 128-03.jpg
http://www.files.classicalgasemissions. ... 128-04.jpg
http://www.files.classicalgasemissions. ... 128-05.jpg
http://www.files.classicalgasemissions. ... 128-06.jpg
http://www.files.classicalgasemissions. ... 128-07.jpg
http://www.files.classicalgasemissions. ... 128-08.jpg
http://www.files.classicalgasemissions. ... 128-09.jpg
http://www.files.classicalgasemissions. ... 128-10.jpg
http://www.files.classicalgasemissions. ... 128-11.jpg
Does anyone know what computer the case originally belonged to? The only thing identifying it is the name "Sperry".
http://www.vintage-computer.com/vcforum ... hp?t=23836
Helt otroligt! Någon har alltså byggt en C128D med dubbla diskettstationer: 1571 + 1581 inuti lådan av vad som förmodligen varit en Sperry disk controller eller liknande. Inuti sitter det bl.a. en hemmabyggd cartridgeexpander med Epyx Fastload, REU m.m. som hålls samman med skumplast och eltejp. Den som byggt verkar ha lagt till några extra portar, samt en panel med omkopplare för att välja enhetsnummer på diskettstationerna, skrivskydd på/av, välja ROM och JiffyDOS m.m. Kanske inte supersnyggt bygge varken från utsidan eller insidan men absolut någon som ville maximera sin C128 när det begav sig.
Re: Världens mest ombyggda Commodore 128D?
Inläggav sledge » 3 februari 2011, 20:13
Fan vad coolt. Han hade hittat den i en kartong på en återvinningsstation, och tyckte att den såg klurig ut. Hur paff skulle man inte bli när man kom hem och såg vad det var man hittat? Tufft..
Vad folk slänger! :shock:
Inläggav hedning » 3 februari 2011, 20:56
Svintufft! :melting:
...::] Genesis Project - Accept No Limits [::...
SX-64, C64GS, silver badge c64, Brödbox, C64C, C64G, Drean C64C, VIC20, Plus/4, C16, C116, C128, C128D, Atari 520 STfm, Atari 1040 ST, Atari Falcon 030, Amiga 500, Amiga 600, Amiga 1200, CDTV.
hedning
Inläggav Garamath » 7 februari 2011, 20:13
Ja jäklar!
Apropå att slänga saker, träffade jag en person som förra våren slängde sin helt fungerande 64 med en massa spel, en skärm, en 1571 och en 1581 mm! :bigeyes:
Där blev det en lååång paus i vårt samtal...
//Garamath
Garamath
Inläggav herdware » 7 februari 2011, 20:47
^ Bild
Jag kanske drömmer nu men jag har för mig att Fred Bowens C128D också var nåt i hästväg. Fan vet var jag läste det dock...
Inläggav hedning » 7 februari 2011, 21:01
Garamath skrev:en person som förra våren slängde sin helt fungerande 64 med en massa spel, en skärm, en 1571 och en 1581 mm!
:shock: :evil:
hedning
Inläggav carlsson » 27 maj 2011, 09:01
Det här är en annan C128D, inbyggd i skalet till en Commodore PC-5. Samma koncept men inte samma maskin.
